Stránka 2 z 5
Re: Skin HD Glass 16
Napsal: 26 úno 2011, 17:54
od schmegea
HD Glass16 ver. 2.27
- added detection of multichannel audio (new dynamic icon - audio)
- fix timeshift osd messages
- fix detection of ac3 audio in some vu+ images
- added detection of marker and bouquet in channel selection screen (marker and bouquet picons by ftryskac, thx)
- added support for Nemesis 2.2
Napsal: 26 úno 2011, 20:13
od lukas1107
schmegea píše:HD Glass16 ver. 2.27
s touto verzi se mi prestalo zobrazovat epg nevis co stim?
Napsal: 27 úno 2011, 14:45
od schmegea
zkus tento
2.30
- added watchdog and autorestore after update ( when some skin files are changed after update of image)
- small fix of screen 1 and 8
- added the symbol of degree (sat position in channel selection screen and in infobar info)
- changed the picon of bouquet (bouquet by ftryskac, thx)
Napsal: 06 bře 2011, 17:01
od schmegea
2.31
- update of sat description
- changed the piconProv of CSlink (piconProv by ftryskac, thx)
Napsal: 13 bře 2011, 17:49
od schmegea
2.32
- fix overwrite blue line by icon rec ( all screens )
- bigger update of the piconProv and small update piconSat (piconProv, piconSat by ftryskac, thx)
change picture - instalovat jen pokud je aktivní list menu, pak je možné se vrátit na icon menu.
- změna barvy epg
- keymap.xml od robinek
Napsal: 13 bře 2011, 20:57
od schmegea
oprava pro image GP3, kde je zelené tlačítko namapováno na vyvolání nabídky Plugins
Napsal: 15 bře 2011, 19:51
od schmegea
HD Glass16 ver. 2.33
- added encoding.conf to autorestored files, when update of image is detected
Napsal: 23 dub 2011, 22:16
od schmegea
hd glass 2.59
Napsal: 25 dub 2011, 21:22
od schmegea
2.61
- fix restoring type of menu
Napsal: 13 črc 2011, 22:41
od peter808
HD Glass16 ver. 2.94
- fix "cutting" of current EPG in some screen
- added option to the path assignment of icons sets
- added option to transfer the icons on the selected destination (this transfer space becomes about 1.5MB - advantageously be used in case of using image in flash - more free space in root)
- added automatic detection update the skins (future updates) and removing default icons sets reinstalled by instalation, if they were moved in an earlier version
Napsal: 22 srp 2011, 17:13
od peter808
HD Glass16 ver. 3.17
- added message "transporder info not found" and "Reference: X:X:X:...." if selected item have not valid Reference/transporder info - channel selection screen
Napsal: 06 zář 2011, 09:40
od likre
HD Glass16 ver. 3.24
- changed priority measurement HDD temperature - smartctl highest priority, via binary lowest - both methods do not need wake up HDD - in this case HDD must supported S.M.A.R.T.
Napsal: 07 zář 2011, 10:49
od likre
HD Glass16 ver. 3.25
- added screen 13,14,15 and icon set 6 - if you will use screen13, switch icons set to 6 (short icons)
- small update piconProv
Napsal: 09 zář 2011, 11:30
od likre
HD Glass16 ver. 3.26
- fix user info screen
Napsal: 09 zář 2011, 21:39
od likre
HD Glass16 ver. 3.28
- fix sreens 13,14,15
- changed name of labels in enhanced screen - updated in all screens and "more ECM, TP screen"
- fix icons set 6
- added active caid:ecm pid
- changed len of cutting of address
- changed refresh ecm info from 15s to 6s - optimalized with events timing in main code
