Skin HD Glass 16
- schmegea
Re: Skin HD Glass 16
HD Glass16 ver. 2.27
- added detection of multichannel audio (new dynamic icon - audio)
- fix timeshift osd messages
- fix detection of ac3 audio in some vu+ images
- added detection of marker and bouquet in channel selection screen (marker and bouquet picons by ftryskac, thx)
- added support for Nemesis 2.2
lukas1107
s touto verzi se mi prestalo zobrazovat epg nevis co stim?schmegea píše:HD Glass16 ver. 2.27
- schmegea
zkus tento
2.30
- added watchdog and autorestore after update ( when some skin files are changed after update of image)
- small fix of screen 1 and 8
- added the symbol of degree (sat position in channel selection screen and in infobar info)
- changed the picon of bouquet (bouquet by ftryskac, thx)
2.30
- schmegea
2.31
- update of sat description
- changed the piconProv of CSlink (piconProv by ftryskac, thx)
- schmegea
2.32
- fix overwrite blue line by icon rec ( all screens )
- bigger update of the piconProv and small update piconSat (piconProv, piconSat by ftryskac, thx)
change picture - instalovat jen pokud je aktivní list menu, pak je možné se vrátit na icon menu.
- změna barvy epg
- keymap.xml od robinek
- změna barvy epg
- schmegea
oprava pro image GP3, kde je zelené tlačítko namapováno na vyvolání nabídky Plugins
- schmegea
HD Glass16 ver. 2.33
- added encoding.conf to autorestored files, when update of image is detected
- schmegea
hd glass 2.59
- schmegea
2.61
- fix restoring type of menu
peter808
HD Glass16 ver. 2.94
- fix "cutting" of current EPG in some screen
- added option to the path assignment of icons sets
- added option to transfer the icons on the selected destination (this transfer space becomes about 1.5MB - advantageously be used in case of using image in flash - more free space in root)
- added automatic detection update the skins (future updates) and removing default icons sets reinstalled by instalation, if they were moved in an earlier version
AZ Box Premium HD E2-Open RSI 3.0(cccam 2.3.0)+2xSG2100,Illusion M5, Sky link,T&T a celá Európa:-), LG 50PK350&Samsung LE32R71B
peter808
HD Glass16 ver. 3.17
- added message "transporder info not found" and "Reference: X:X:X:...." if selected item have not valid Reference/transporder info - channel selection screen
likre
HD Glass16 ver. 3.24
- changed priority measurement HDD temperature - smartctl highest priority, via binary lowest - both methods do not need wake up HDD - in this case HDD must supported S.M.A.R.T.
Azbox HD Elite,Openrsi 3.0 Kernel v3.3.1,Samsung G3 Station 1TB , multifeed 4 lnb(28.2+23.5+19.2+13),Skylink,Samsung LE40B650
likre
HD Glass16 ver. 3.25
- added screen 13,14,15 and icon set 6 - if you will use screen13, switch icons set to 6 (short icons)
- small update piconProv
likre
HD Glass16 ver. 3.26
- fix user info screen
likre
HD Glass16 ver. 3.28
- fix sreens 13,14,15
- changed name of labels in enhanced screen - updated in all screens and "more ECM, TP screen"
- fix icons set 6
- added active caid:ecm pid
- changed len of cutting of address
- changed refresh ecm info from 15s to 6s - optimalized with events timing in main code
- fix icons set 6
