Oscam 2901 - diskusia
dym1
Re: Oscam 2901 - diskusia
Oscam user
[account]
user = hdbox
pwd = hdbox
disabled = 0
expdate =
group = 1
hostname =
uniq = 0
sleep = 0
monlevel = 2
services =
caid = 0D03
betatunnel =
ident =
cccmaxhops = 10
keepalive = 1
numusers = 0
penalty = 0
Oscam conf
[newcamd]
port = 15000@0D03:000004,000008
allowed =
keepalive = 1
mgclient = 1
Oscam server
[reader]
label = dolna_citacka
enable = 1
protocol = internal
device = SC0
services =
caid = 0D03
detect = cd
mhz = 500
cardmhz = 357
ident =
group = 1
ecmcache = 1
blockemm-unknown = 1
blockemm-u = 1
blockemm-s = 1
blockemm-g = 1
Newcamd list
CWS_KEEPALIVE = 500
CWS_INCOMING_PORT = 12000
CWS = 127.0.0.1 15000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14
[account]
user = hdbox
pwd = hdbox
disabled = 0
expdate =
group = 1
hostname =
uniq = 0
sleep = 0
monlevel = 2
services =
caid = 0D03
betatunnel =
ident =
cccmaxhops = 10
keepalive = 1
numusers = 0
penalty = 0
Oscam conf
[newcamd]
allowed =
keepalive = 1
mgclient = 1
Oscam server
[reader]
enable = 1
protocol = internal
device = SC0
services =
caid = 0D03
detect = cd
mhz = 500
cardmhz = 357
ident =
group = 1
ecmcache = 1
blockemm-u = 1
blockemm-s = 1
blockemm-g = 1
Newcamd list
CWS_KEEPALIVE = 500
MartinK.
TADY je můj problém.
maximální spokojenost
Erzo
Skus opravit na newcamd.list:056152 píše:Zdravím
Snažím se spojit OSCAM 2901 z MGCAMDem ale nedáříse.
Mám dvě karty SKYLINK a TNK
TNK v horní čtečce SC1
Skylink v dolní čtečce SC0
v OSCAM.CONF nastaveno port = 15001@0D03:000000;15002@0B00:000000
v OSCAM.USER nastaveno
[account]
user = jmeno
pwd = heslo
Group = 1
betatunnel = 1833.FFFF:1702
CAID = 0D03
1702,1833,1830
au = 1
services = skylink
v OSCAM.SERVER nastaveno
## TNK
[reader]
Label = TNK
Protocol = internal
Device = SC1
services = tnk
detect = CD
EMMCache = 1,3,2
group = 1
mhz = 368
cardmhz = 368
CAID = 0B00
disableserverfilter = 1
IDENT = 0B00:000000
## Skylink-dolna
[reader]
Label = Skylink
Protocol = internal
Device = SC0
services = skylink
detect = CD
#EMMCache = 1,3,2
group = 1
CAID = 0D03
IDENT = 0D03:000000
blockua = 1
blockga = 1
blocksa = 1
blockemm-u = 1
blockemm-s = 1
blockemm-g = 1
a v NEWCAMD.LIST NASTAVENO
CWS_KEEPALIVE = 300
CWS_INCOMING_PORT = 15000
CWS = 127.0.0.1 JMENO HESLO 01 02 03 04 05 06 07 08 09 10 11 12 13 14
VÝSLEDEK
Karta TNK funguje programy se ekoduji ale karta SKYLINK se nepřipojí nemůžu na to přiít proč jakoby se mgcamd nechtěl připojit na port kde je karat SKYLINK.
Hledám nějakou dobrou duši která by s tím pomohla už jsem zkoušel co mě napadlo ale furt nic.
Bude to nějaká kravinka protože OSCAM ver 2422 mi funguje všechno. Teť jen přijít nato co nové verzi vadí.
CWS_KEEPALIVE = 300
CWS = 127.0.0.1 15001 JMENO HESLO 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS = 127.0.0.1 15002 JMENO HESLO 01 02 03 04 05 06 07 08 09 10 11 12 13 14
TV LCD LG 37LH5000, DM800 HD OEM, Octagon FS 1018 - HDD 160GB, Toroidal T55 (39,0°E + 28,2°E + 23,5°E + 19.2°E + 13,0°E + 9,0°E + 4,8°E + 0.8°W), Wireless USB - D-Link DWL-G122, Router - Linksys WRT160N, Router - Asus WL-500gP V2 - Oleg + Oscam
MartinK.
skus opravit na newcamd.list:
CWS_KEEPALIVE = 300
[quote="056152"]Zdravím
SORRY výborný postřech ale to tam samozdřejmě mám jenom jsem to ce svém příspěvku neuvedl teť už je to opravené
CWS_KEEPALIVE = 300
dym1
A co oscam conf
[dvbapi]
enabled = 1
au = 0
boxtype = none
user = hdbox
pmt_mode = 0
ignore = 0100,0D96,0624,09C4,09C7,0D70
[dvbapi]
enabled = 1
au = 0
boxtype = none
user = hdbox
pmt_mode = 0
Erzo
Ked on pouziva mgcamd tak netreba.dym1 píše:A co oscam conf
[dvbapi]
enabled = 1
au = 0
boxtype = none
user = hdbox
pmt_mode = 0
[dvbapi]
enabled = 0
- joloSK
Posledny plugin Oscam 0.99.4 svn 2901 - HDBOX z 21.8.2010 je best.
Perfektna praca, co sa tyka grantecovej prace sklanam sa az po zem
. Je to najlepsi plugin doposial, co sa tyka univerzalnosti a stabilitu zacinam testovat, ale verim ze bude vyborna
Este raz "VELKA VDAKA"
exhornik
Zdravim,
vcera jsem trochu potrapil Oscam 2901 - mam nasledujici postrehy:
1. rozchozeni celkem v pohode - zkousel jsem jak nastaveni od Grantece (chybi tam jenom loadbalancing) - s nastavenim services jsem nemel problemy (testoval jsem variantu, zaklad 0D03 ve ctecce a pay 0D03 z newcs serveru na AzBox). Dal jsem zkousel settings od Erzo, protoze mam starou kartu a jeste tam neni NovaHD, tak jsem ji potreboval brat ze share, coz jsem resil pres parametr services v souboru oscam.server a upravu konfigurace v oscam.services - v tomto souboru services je jedina chybicka a to je TVBarandov, ktera je zadana jak v servisce skylink/skylink_share, tak v servisce skylink_ignore/skylink_share_ignore (v souborech, ktere jsou v priloze uz to je opraveno). Pripojeni na newcs pres newcamd probehlo naprosto bez problemu. Cteni z interni karty mi pripada ze zacatku pomalejsi (asi nez se naplni cache), pak uz prepinani funguje celkem v pohode - i kdyz na mem HD-Boxu se to neda s Xcamem srovnat - dle meho subjektivniho nazoru prepina Xcam rychleji.
2. Skvela je moznost nastavit si co odkud se ma cist - to je fakt super a skutecne to funguje velmi dobre. I zobrazeni ve webrozhrani nastavovani perfektne pomaha, protoze je videt co se odkud cte.
3. Co se tyka stability, tak na mem HD-Boxu dost spatny. I pri nastaveni loadbalancingu dochazelo k zaseknuti cca kazdych 5 minut a to jak pri cteni z interni karty (coz bylo podle me jeste o malinko horsi - je to mozna dano tim, ze moje karta je hodne stara) tak i pri cteni pouze z newcs. Skoro bych rekl, ze pokud jsem mel nastaveno jak cteni z karty, tak cteni z newcs, tak k zasekavani pri cteni z newcs serveru nedochazelo tak casto. V momente kdy jsem zakomentoval v oscam.server interni ctecku a restartoval, tak se podle me subjektivne vypadky pri cteni z newcs zhorsily. Dival jsem se do webrozhrani a vzdy kdyz doslo k vypadku tak se na strance zobrazilo ... reader timeout 5252 (tim cislem si nejsem uplne jisty). Pote dekodovani skoncilo (na obrazovce napis Program zakodovan), ale pokud jsem prepnul na jiny kanal tak se dekodovani zase rozjelo a vse zase na chvili fungovalo normalne. Nepodarilo se mi nijak presvedcit oscam, aby se nezasekaval - mozna mam jenom blbe nastavene parametry, proto prosim znalejsi jestli by byli tak hodni a mrkli na moje soubory s nastavenim. Posilam oba:
1. skylink_all_share.zip - cteni komplet 0D03 z newcs
2. skylink_zakladkarta_payshare.zip - cteni zakladu z karty a pay z newcs
ja pouzivam uz len Oscam.
mam zakazany webif , zakazany server newcamd a cccam a pouzivam len citacku a vzdialeny pristup .
Pouzival som na 1.08.26 . Potom som dal 1.08.34 a teraz mam 1.08.38 . Ide to v pohode. CItacka sa neseka a loadbalance nepouzivam vobec . Prave s jeho pouzivanim byval problem. A aj som napisal k verzii - stabilny -pri minimalnom modofikovani kofiguracie. Naprikald pre server,kde mam 0d03 a aj 0d0f vobec nepouzivam service - jedine co mam v dvbapi je ignore a potom pri uzivatelovi betatunel na sky germany. Pri internej citacke a karte som ziadne chyby nezaznamenal .
Podotykam,ze je to dane len skusenostami ,proste- chce to prax , zopar pokus/omyl zmien a musi to fungovat. Cez vikend by sme s dempseyom chceli zas skusit na AZboxe Oscam s internou citackou , takze zas nejake skusenosti pribudnu .
- Libor73
Ahoj, ted kvuli zakazanym zapisum na kartu T&T pouzivam Xcam. Rad bych ale brzo pouzil HD Box jako server. Bude mi k tomu stacit Oscam? Nebo jeste v kombinaci s jinym pluginem?
jerry
staci oscam. V podstate je to velmi dobre konfigurovatelny klient i server.
Ja som tiez osekal oscam snad o vsetko... a tie 2 konfiguraky co zostali su velmi lahko citatelne :)
jerry
- Libor73
Super..diky za reakci..a k tomu plugin na emu?jerry píše:staci oscam.
exhornik
Taky nevim o tom, ze by byl 1.08.38 :eek: Jeste se zeptam, pouzivate pro dekodovani interniho klienta OSCAMU (jestli dobre chapu tak je to zrejme to DVB-API). Nebo pouzivate OSCAM jenom jako ctecku a mate k nemu pres newcamd pripojeny XCAM ? Protoze v konfiguraci DVB-API mi pripada divny ten user dummy. V souboru oscam.users, zadny takovy uzivatel neni, tak moc nerozumim tomu jak to vlastne funguje.
Nicmene i informace o tom, ze se chysta OSCAM na interni ctecku pro AzBox je zajimava - jestli muzu nejak pomoci pri testovani tak dejte vedet, protoze chovani meho AzBoxu s verzi fw vyssi nez 0.9.4890 je otresne.
jerry
ziaden Xcam, ziadny mgcamd, ziadny newcsd.
ano "interny klient" = dvb api
uzivatel dummy je naozaj dummy :) vymaz, uvidis
