Stránka 2 z 2
Re: Open PLI 2.1 - Pomoc prosím....
Napsal: 23 bře 2013, 21:01
od dusan.novotny
gorick píše:Chces pouzivat oscam na kartu a cccam na zdielanie? Dost neprakticke, ale ak ti nevadi medzi nimi stale prepinat...
edit: a sice mozno je to jedina moznost, lebo neviem, ci ten oscam pre i-deto dokaze robit newcamd/cccam klienta
Chces nastavit cccam, aby bol klientom, ale nevieme, ci
1. server je iny box doma a v nom je karta? alebo 2. server je vzdialeny /zahranicny/ a aky protokol pouziva /newcamd, cccam/?
Takto, kartu mám ale neužívam.
Chcem nastaviť cccam, aby bol klientom, kde server je zahraničny a protokol je cccam....
Napsal: 23 bře 2013, 21:10
od JohnCenaWWE
CCcam.cfg atributy 644 takto si to daj
### Config File Created by Cam-Editor ###
### Cam-Editor ©2006-2008 Oermens ###
##### CCcam-Editor 2.0.5 #####
# BLOKER: #
#### Servers ####
#### C: Line privat ####
C: ip port meno heslo
#### C: Line on ####
#### C: Line test ####
#### N: Line ####
#### Config ####
# SERVER LISTEN PORT : #
SERVER LISTEN PORT : 12000
# ALLOW TELNET INFO : #
ALLOW TELNETINFO: yes
# ALLOW WEB INFO : #
ALLOW WEBINFO: yes
# WEBINFO USERNAME : #
WEBINFO USERNAME :
# WEBINFO PASSWORD : #
WEBINFO PASSWORD :
# TELNETINFO USERNAME : #
# TELNETINFO PASSWORD : #
# TELNET INFO LISTEN PORT : #
TELNETINFO LISTEN PORT : 16000
# WEB INFO LISTEN PORT : #
WEBINFO LISTEN PORT : 16001
# ZAP OSD TIME : #
ZAP OSD TIME :0
# OSD USERNAME : #
OSD USERNAME :root
# OSD PASSWORD : #
#OSD PASSWORD :
# OSD PORT : #
OSD PORT :80
# SERIAL READER : #
# SMARTCARD WRITE DELAY : #
# SMARTCARD CLOCK FREQUENCY #
# EMM Blocker #
# SHOW TIMING : #
SHOW TIMING : no
# DEBUG : #
DEBUG : no
# NEWCAMD CONF : #
NEWCAMD CONF :no
# DISABLE EMM : #
DISABLE EMM : no
# EXTRA EMM LEVEL : #
EXTRA EMM LEVEL : yes
# Mini OSD #
MINI OSD : no
# CAM KEY #
# CAMDATA #
# BOX KEY #
# BEEF ID : #
# PIN : #
# SOFTKEY FILE : /usr/keys/SoftCam.Key #
# LOADBALANCE : #
# TRY ALL CHIDS : #
# POSTINIT : #
# DVB API : #
# SHOW EXTENEDED CLIENT INFO : #
# EMM THREADS : #
EMM THREADS : 1
# MINIMUM DOWNHOPS : #
MINIMUM DOWNHOPS: 0
Napsal: 23 bře 2013, 21:16
od dusan.novotny
OK. ale keďže som nahodil cez GSU CCcam 2.1.3 tak kde teraz cez FTP mám nájsť Cccam.cfg súbor?
v etc nie je.....
Napsal: 23 bře 2013, 21:17
Čo Ti bráni v tom aby si ho tam odniekiaľ skopíroval alebo ho v etc vytvoril?
Napsal: 23 bře 2013, 21:19
od JohnCenaWWE
sak ty nemas ani ten subor!!!!tu je pes zakopany vytvor si textovy subor a nahraj co som sem dal a zadaj si svoje hodnoty stary cccam si odinstaluj nech ti tam nezavadzia
CCcam.cfg musi byt v etc/CCcam.cfg
Napsal: 23 bře 2013, 21:21
od gorick
...alebo vsetko v cccam.cfg vymazat a nechat tam len 1 riadok
C: server port meno heslo /server-bud cely nazov alebo len IP adresa/
...cccam.cfg kopirovat do etc/ alebo var/etc
Napsal: 23 bře 2013, 21:37
od dusan.novotny
JohnCenaWWE píše:sak ty nemas ani ten subor!!!!tu je pes zakopany vytvor si textovy subor a nahraj co som sem dal a zadaj si svoje hodnoty stary cccam si odinstaluj nech ti tam nezavadzia
bol tam, zmazal som ho......
ale teraz už mám guláš....
Keď Cccam stiahnem v Moduloch a nainštalujem v Softcam/CI tak potom v etc ten Config súbor je.
Pokiaľ ho dám z moduloch preč a nainštalujem len cez GSU tak tam nieje.....
Tak ako teraz.....
Napsal: 23 bře 2013, 21:41
Ak ho nemáš / asi neni súčasťou inštalačky z GSU / a chceš ho používať tak si ho tam kua daj
Napsal: 23 bře 2013, 21:43
od JohnCenaWWE
GSU konfiguraky nema ale sak si ho vytvor ako som napisal
Napsal: 23 bře 2013, 21:45
od brano2405
Instalovany cez GSU tam nieje, musiš si ho tam dať. Mal som ten isty problem
Napsal: 23 bře 2013, 21:58
od dusan.novotny
dempsey píše:Ak ho nemáš / asi neni súčasťou inštalačky z GSU / a chceš ho používať tak si ho tam kua daj
Kua Dempsey už to ide......
No dobre, na dnes už aj stačilo, manželka môže konečne kukať telku bez toho aby mi nadávala že to mrzne atď. ako to bolo doteraz na starom fw.
Paráda.
Zajtra budem študovať ďalej, aby sme doladili ešte zopár detailov.......ako je napr. nahrávanie.
Ešte jedna taká rýchla otázka, OK tlačítko nefunguje? na dialkovom som pužíval spodnú klávesnicu na rýchly voľbu programov, pôjde mi to aj teraz?
Dikes chlapi. Som rád že s vašou pomocou sa mi ten prechod na 1-krát podaril.......
Pekný večer prajem.....
Napsal: 01 dub 2013, 21:02
od stano75
DO v E2 funguje trosku inak ako v ofiko FW. Ale da urobit vlastny keymap.Ale lepsie bude ked si zvyknes na to ako to je teraz
