^New FW 1.25
^New FW 1.25
http://www.multiupload.com/TOKFGUP7NB
1, Switch Patch OFF (F1+000) havent effect switch OFF , sharing G-share continue
***from factory reset some time still working G-SHARE , or if is inside card that working channels by gshare which arent like PPV on the card
----------------ok
2, Incorect sound track name at channel , Slovakia = Svahili , same at anothers
*** stil is bad ...
3, At recorded files problem with change soundtrack
--------about 3,4 point,we checking .will fix next sw.
4 , Incorect characters EPG czech channels UPC 1W
***still bad characters is show
---------ok ,fixed
5, Web radio incorrect characters , earlier s/w (1.11 OK)
*** isnt possible check , s/w higher then 1.17 dont working radio
--------ok ,fixed
6, very short time for putting directly channels from RCU --- , 12 , 125
---------ok ,fixed
7, time after time different function is happen by press button
optimize remote control (many times frezz and we must wait few sec. for back to work)
this process "opt/nxp/bin /appHuangpu" some time load CPU in 100% !!!
-----more improved
8, Incorect polish characters ł etc
---------ok ,fixed
9, EMM ON/OFF
***dont
----------------ok,you can setup on/off on "system---system setting---CA EMM blocker"
10, sensitivity for moving of mouse -web browser is high
----cannot improve .nxp8735 cpu speed limit
12, when is priority list , is possible add ignire list , some channels long time then show picture
------you can use oscam .it has this function .you can set igore list from web.
13, info about scrambled system isnt show Cryptoworks (only Irdeto , nagra etc)
***OK
14, last s/w some changes with WIFI drivers , some USB WIFI sticks now dont working
***still same
15, show bar process of current programme length from current EPG
***dont
------ok,added
16, Formating of HDD dont working
------ok,fixed
17 , isnt show subscription fee from access card ¨
***time after time is show , but is depent by for us unknow happen
18 , support of new Irdeto cards
*** maybe with OSCAM , but oscam problem with timing of cardreader or ....
19, SKY premiera cards CAID 1702 dont working (card we have already in office
---------ok ,fixed
20, some CZ text in OSD menu/editace Kanálů/,,Uživatelská Seznam,, (Záloha Systémové nastavení)
Špatný překlad Cz v menu /instalace/,,Fast Scan,, (Rychlé hledání)
***next part is oK , but are there some englis still
21, lasts s/w probably dont passing EMM to cryptoworks cards , need check again
***maybe yes
22 , when is set recording shedule by EPG , time after time is stored file with name previous event
------ok
23, sorting of channels ...
24, at recorded file is from EPG getting bad name relation wit point 22..?
-------ok
25, FTP access , open /VAR for plugins , in OSD add choice ,start stop own plugins (protocols )
------cannot suport this function.
26, from Audio digital out - coaxial at some media files playing from USB or network isnt working multichannel sound , dont working by coaxila out
------we
27 , Add possibility for detailed setup of NewCS, [mapping , etc. for example for S.K.Y G.E.R.M]
without mapping is not possible receive HD channels from the same packet as SD , which have different CAID as SD packet
For example:
Newcamd protocol is recommended;
Use F: { 01 } parameter in mg_cfg file;
Delete X: { 18 33 } entry from ignore.list if you find it.
Add a mapping to CAID 1702 for all channels in the replace.list
HD channels of the package will open without problem.
------you can use oscam .it has this function .you can setup from web.
28, add possibility timeshift ON/OFF
-------can not support this function
29, possibility change color of subbtitle , change site , for media player
------ok,change it to more bigger and yellow color
30. add to menu position - function Reboot , STB still isnt stable and many time is need swith OFF/ON power
------ok,fixed
31. still many restart -reboot with use web radio ........
***every s/w after 1.17 dont working youtube , web radio
--------ok,fixed
32. subtitles for movies are still desychronized .
---------you can adjust offset by TTX key when u slected stitle from sub menu
33. in youtube change quality of video - resulition etc....
--------you can press SUB Key to change display fit mode when u watching youtube
----------------ok
*** stil is bad ...
---------ok ,fixed
--------ok ,fixed
---------ok ,fixed
-----more improved
---------ok ,fixed
9, EMM ON/OFF
***dont
***OK
***still same
***dont
------ok,added
------ok,fixed
---------ok ,fixed
***maybe yes
------ok
-------ok
------we
For example:
------ok,fixed
--------ok,fixed
Re: ^New FW 1.25
... no tak podle toho co ctu, tak obrovsky posun kupredu. Konecne aspon dle popisu podpora FTP a otevreni adresare VAR pro pluginy, oprava EPG na 1W atd. Bohuzel, instalovat a testovat muzu nejdrive az zitra, tak jestli bude nekdo testovat drive, tak at se urcite podeli o prvni postrehy...
HDBox FS-9100 PVR
Amiko SHD-8900 Alien
Optibox TSCX PVR Ready
Dreamsky NXP256HD
GOLDEN MEDIA UNI-BOX 9080 CRCI HD COMBO
Dreamsky NXP256HD
- ShaMan
Re: ^New FW 1.25
Je tam chyba v obsluze čtečky , je třeba počkat na opravu (misí bát zaplý patch F1+000)
, jinak je tam přidáno EMM ON OFF
informace o trvání programu - graficky
a nějaké další
zbytek čeká na odstranění ...
a nějaké další
Re: ^New FW 1.25
Chapu to spravne, ze pokud je zapnuty patch, interni ctecka jede OK ?
Vu+ Duo VTI 2.x OSCAM 1.00svn build #5xxx CCCAM 2.2.1, Dreamsky 7500 LAN PVR 2.53 GSH+,
Technisat MF4-S CC & XCAM Orion 3100, Ferguson Ariva 200 1.07b*
DreamSky NXP256HD
DreamSky NXP256HD
- hitman222
Re: ^New FW 1.25
U mne porad zakodovano,odpojovalo se to,po prepnuti programu 3 krat reboot. Uz je zpet 1.16
Dream800 HDse_OpenPli
Vu+Solo2_OpenPli
Cloud-ibox3_OpenPli
Dreambox 7020,Dreambox 500
Samsung UE46ES8000
motor SG2100(SKY Link)
Vu+Solo2_OpenPli
Cloud-ibox3_OpenPli
Samsung UE46ES8000
Re: ^New FW 1.25
dk_line píše:... no tak podle toho co ctu, tak obrovsky posun kupredu. Konecne aspon dle popisu podpora FTP a otevreni adresare VAR pro pluginy, oprava EPG na 1W atd. Bohuzel, instalovat a testovat muzu nejdrive az zitra, tak jestli bude nekdo testovat drive, tak at se urcite podeli o prvni postrehy...
No nevim co jsi cetl / spis prelozil, ale je tam jasne uvedeno, ze tato funkce nemuze byt podporovana :sad:
Takze bohuzel ...
DREAMSKY NXP256HD , FW 1.21, Oscam active, Dual LNB - 19,2 ; 23,5
Re: ^New FW 1.25
:sad: mas pravdu, omlouvam se... prehledl jsem totessi píše:No nevim co jsi cetl / spis prelozil, ale je tam jasne uvedeno, ze tato funkce nemuze byt podporovana :sad:
Takze bohuzel ...
HDBox FS-9100 PVR
Dreamsky NXP256HD
Dreamsky NXP256HD
005jon
- Dostal poděkování: 192 poděkování
Re: ^New FW 1.25
Kto nemá chuť testovať tak nech ho tam ani nedáva .
Tak ako píše hitman222 reštartuje alebo zamrzne , nedokáže dekódovať program jednoducho celí zblbne a potom nejdú ani voľne programy napiše kodovane treba ho manuálne zreštartovať je tam ta istá chyba ktorá bola aj na FW 1.24
- AB DSR-322
