Oscam L2B
Re: Oscam L2B
[account]
User = dreambox
Pwd =
Group = 1
au = 1
monlevel = 2
[account]
User = monitor
Pwd = monitor
Group = 1
monlevel = 2
# oscam.server generated automatically by Streamboard OSCAM 1.20-unstable_svn SVN r11061
# Read more: http://www.streamboard.tv/svn/oscam/tru ... server.txt
[reader]
label = skylink
protocol = internal
device = /dev/sci0
caid = 0624
detect = cd
boxkey = B1B2B3B4B5B6B7B8
rsakey = AB722A8CAA9F58DE0D1CBB6FF329C961ED9DD759B103082D1BAE64C27A861D42E7F631891C2660EFA57484F80BBB4E0E8249A8368E31BD3FFC369FBE95160528
force_irdeto = 1
mhz = 600
cardmhz = 600
group = 1
emmcache = 0,1,3,0
[reader]
label = skylink
protocol = internal
device = /dev/sci1
caid = 0624
detect = cd
force_irdeto = 1
mhz = 600
cardmhz = 600
group = 1
emmcache = 0,1,3,0
# dvbapi configuration
# types:
# P - Priority
# format:
# P: <caid>:[<provider>]:[<srvid>]:[<ecmpid>]
# I - Ignore
# format:
# I: <caid>:[<provider>]:[<srvid>]:[<ecmpid>]
# M - Map
# format:
# M: <caid>:[<provider>]:[<srvid>]:[<ecmpid>] <target caid>:[<target provider>]
# D - Delay
# format:
# D: <caid>:[<provider>]:[<srvid>]:[<ecmpid>] <delay (ms)>
P: 0624
I: 0
User = dreambox
Pwd =
Group = 1
au = 1
monlevel = 2
[account]
User = monitor
Pwd = monitor
Group = 1
monlevel = 2
[reader]
label = skylink
protocol = internal
device = /dev/sci0
caid = 0624
detect = cd
force_irdeto = 1
mhz = 600
cardmhz = 600
group = 1
emmcache = 0,1,3,0
[reader]
label = skylink
protocol = internal
device = /dev/sci1
caid = 0624
detect = cd
force_irdeto = 1
mhz = 600
cardmhz = 600
group = 1
emmcache = 0,1,3,0
# types:
# P - Priority
# format:
# I - Ignore
# format:
# M - Map
# format:
# D - Delay
# format:
P: 0624
I: 0
baranček
Re: Oscam L2B
tak toto som vyskúšal pre Teba.Image open ATV 6.4 stiahnutý oscam-stable-IPv4 only.Posielam Ti balíček,ktorý funguje.Ti si len stiahni spomínaný oscam,ak ho máš náhodou už stiahnutý len prepíš moju zaslanú binárku oscam-stable v adresári usr/bin pri vypnutom oscame a nakonfiguruj si moje priložené configy v adresári etc/tuxbox/config/oscam-stable.Urob reštart GUI a reštartni oscam -stable
Re: Oscam L2B
Zdravím pánové. Mohu poprosit o radu někoho zkušeného ,který by mě navedl ,kde dělám chybu při nastavení oscamu? Potřebuji sdílet kartu s druhým dreamboxem v patře na stejné síti, ale nedaří se mi nastavit. Používám protokol newcamd ,ale buhužel fungují max 4 programy. Se starým oscamem 11202 funguje normálně. Díky za případné rady.
Re: Oscam L2B
Mám ještě pár otázek. Oscam jsem stáhl ten co mi doporučil Warder. Soubory co jsi mi popsal patří všechny do "config" nebo právě oscam-stable je daný oscam, co mám stáhnout a nahrát do usr/bin (nemůžu ale tu napsanou verzi najít). A poslední dotaz - v adresáři config má být ještě složka oscam-stable nebo tam přímo nakopírovat ty soubory? Omlouvám se, ale fakt začínám a všechny pokusy, co jsem prozatím vyzkoušel, tak selhaly.
EnoSat
Re: Oscam L2B
zalezi ako mas napisany script pre spustenie daneho oscamu
baranček
Re: Oscam L2B
Tak Ty si poriadny zelenáč,zatiaľ si ničomu neporozumel aj keď môj návod je tak zreteľne napísaný a k tomu binárka a configy oscam.user,oscam.server,oscam.dvbapi,oscam.config ako na tanieri.tak ešte raz polopaticky stiahneš oscam stable ,keď cez FTP otvoriš adresár -usr/bin tak tam uvidíš jeho binárku oscam-stable tú musíš prepísať mojou binárkou oscam-stable ktorú som Ti poslal samozrejme oscam musí byť vypnutý.Viem je tu zádrheľ,lebo sa odvolávaš na to,že máš už stiahnutý oscam od Wardera a dokonca prepísaný,ale neuvádzaš aký je to oscam z feedu,či je oscam stable,oscam trunk,oscam imod,alebo aký si z feedu stiahol?To by až tak nevadilo tak šup napísať aký oscam máš stiahnutý a v ňom by sme tú Warderovu binárku prepísali na moju.Napíš mi presný názov tej binárky a by som Ti ju prepísal na môj obraz.Všetky oscam configy čo som Ti poslal patria do adresára etc/tuxbox /config a potom si vyberieš svoj druh oscamu ktorý máš stiahnutý buď je to stable,trunk,imod a otvoríš si ho kliknutím naň a prepíšeš si moje konfigy.Ja som pre Teba robil všetko v oscame -oscam stable stiahnutý z feedu.Na mojom obrázku som Ti jasne ukázal druh oscamu,ktorý tam mám tak definuj aj Ty na ktorom oscame idešrocker07 píše: ↑16 říj 2022, 10:56 Mám ještě pár otázek. Oscam jsem stáhl ten co mi doporučil Warder. Soubory co jsi mi popsal patří všechny do "config" nebo právě oscam-stable je daný oscam, co mám stáhnout a nahrát do usr/bin (nemůžu ale tu napsanou verzi najít). A poslední dotaz - v adresáři config má být ještě složka oscam-stable nebo tam přímo nakopírovat ty soubory? Omlouvám se, ale fakt začínám a všechny pokusy, co jsem prozatím vyzkoušel, tak selhaly.
Re: Oscam L2B
Já jsem postupoval podle návodu Wardera a stáhl jsem tento oscam ze strany 3 tohoto vlákna Oscam-1-20_svn11704-arm-(l2b-patch). Tím jsem nahradil původní oscam. Ale na kódovaných programech byla potom tma. O nějakých úpravách totiž nebylo předtím totiž ani slovo. Tak je možné, že jsem měl udělat něco dalšího. Tak jsem nahrál zpět původní oscam a jeho config jsem ti po tvé žádosti sem nahrál. U něj mi jedou aspoň programy, které nemají vyšší zabezpečení.
Re: Oscam L2B
Ještě dodám, že u tohoto původního oscamu mám v adresáři tuxbox adresáře config1 a config2 a při výběru oscamu dle obrázku mi to nabízí skylink ird nebo freesat.
baranček
Re: Oscam L2B
pane bože konečne mi prezraď aký oscam si stiahol z feedu?.Je to oscam stable,trunk,alebo nejaký iný?
baranček
Re: Oscam L2B
síce nechápem ako si tam dostal ten oscam skylink irdeto a freesat,ale nevadí keď si zvládol návrat späť a zrejme keď máš zapnutý ten oscam irdeto tak Ti to ide po starom.Tak si kľudne môžeš pozrieť ako sa volá Tvoj oscam v adresári usr /bin a podľa tohto názvu prepíš moju binárku pri vypnutom oscame.príklad moja binárka sa teraz volá oscam-stable a po,prepísaní musí mať totožný názov ako binárka v Tvojom oscame v adresári usr/bin.V adresári etc_tuxbox /config si zisti ktorý je pre skylink či 1,alebo 2 a prepíš si tam moje konfigy
EnoSat
Re: Oscam L2B
chybaju ti potrebne kniznicerocker07 píše: ↑16 říj 2022, 14:15 Já jsem postupoval podle návodu Wardera a stáhl jsem tento oscam ze strany 3 tohoto vlákna Oscam-1-20_svn11704-arm-(l2b-patch). Tím jsem nahradil původní oscam. Ale na kódovaných programech byla potom tma. O nějakých úpravách totiž nebylo předtím totiž ani slovo. Tak je možné, že jsem měl udělat něco dalšího. Tak jsem nahrál zpět původní oscam a jeho config jsem ti po tvé žádosti sem nahrál. U něj mi jedou aspoň programy, které nemají vyšší zabezpečení.
Re: Oscam L2B
Děkuji všem, hlavně barančekovi za trpělivost. Konečně to funguje. Postup byl správný, ale vždy chyběla drobnost ke zdárnému konci.
Re: Oscam L2B
Nejdříve chci všem tady poděkovat za diskuzi a rady......ne vždy se najde taková ochota o problému mluvit. Jen se chci zeptat já na několik věcí. Nejsem expert,ale přespat binarku dle návodu mi nedělá problém. Mam Vu+ Ultimo 4K, Solo 4K. U obou VTI 15, nastaveno sdílení, takže jedou na jednu Skylink kartu. Mám nastavenou čtečku - tedy oscam.config na Irdeto, vše fungovalo dobře. Až teď přestala jít Prima Show, Star a nově i Prima HD, ale ostatní programy jdou dobře. Tak jsem dle diskuzí nabyl dojmu, že by to mohlo být Oscam bez lB2. Zkusil jde popsaný a hodně diskutovaný postup. A nakonec - tma......takze nastesti zpět ze zalohy image. Narazil jsem na tyto problémy:
1) v usr/bin - neni Oscam - stable, ale pouze unstable.......ale tim prepisu stazeny zde oscam arm
2) nastavim vse, ale nikde nemuzu najit soubor oscam.dvbapi ?
3) koukal jsem na stavajici config.....ale tam je uplne jine rsakey a boxkey ?? Takze hloupy dotaz, asi, ale to je univerzální nebo se to liší podle typu přístroje ????
Spíš mě štve že to ne a ne rozchodit......a nevim, kde dělam chybu.....
Budu rád za nějaký komentář......
baranček
Re: Oscam L2B
použil som môj balíček na VU solo 4k image VTI 15 a všetko funguje akurát som moju binárku prepísal na oscam unstable. Stiahni si môj priložený balíček a config,reštartni enigmu a reštartuj oscam.
