DreamBoxEdit
005jon
vikino
Re: DreamBoxEdit 4.0.0.0
DreamBoxEdit 4.0.1.0
Quote:
Changelog:
4.0.1.0
- fixed sorting services in bouquet panel was broken after adding channel numbers to the bouquet panel
- fixed error when sorting bouquets with cable and terrestrial services
- fixed some other functions were also broken after adding channel numbers to the bouquet panel
- fixed hour glass didn't get away after loading new settings
- fixed error message when using picon cleanup function and filename wasn't using proper picon reference format
- fixed alternatives are no longer considered as duplicates of fixed services in the same user bouquet
- fixed alternatives handling, now you can use the same service with and without alternatives in one user bouquet
- fixed blacklist entry for radio user bouquets
- fixed all files are now written in proper settings-type 4 format
- fixed auto insert markers for cable and terrestrial services
- added Enigma2 restart button to ftp window, use this button to activate any changes related to lamedb and/or black-/whitelist
use the autoreload or "reload settings on dreambox" button if you only change your userbouquets
- added sorting of profiles in options panel
- changed satellites in filter combobox are now sorted by position from west to east
- changed profile default paths to enigma2 defaults
- window state is now saved on application close, and restored when application is started
- some minor fixes
- language files updated
Quote:
Changelog:
4.0.1.0
- some minor fixes
- schmegea
- Mazák
4.0.1.1
- fixed alternatives filename generation
- fixed error message after opening Enigma1 settings
- fixed total service counter was overlapped by displayed service counter after startup without settings
- schmegea
- Mazák
Changelog:
4.0.1.2
- fixed userbouquets with renamed services are now written in proper settings-type 4 format
- fixed problem when saving cable or terrestrial settings (some parameters were lost)
4.0.1.2
likre
DreamBoxEdit-IHAD Edition 4.1.0.0
Changelog:
4.1.0.0
- added crypto icon in main service list if service is encrypted (Note: this is only working properly on future Enigma2 Images)
- added filter for encrypted and unencrypted services (Note: this is only working properly on future Enigma2 Images)
- added copy service reference to clipboard option to context menu of main service list and bouquet panel
- added a info window with some informations about the new filtering behaviour
- fixed error message when using add new service option in context menu
- fixed application hanging when parsing lamedb with corrupted transponder entry
- fixed problems after adding new services, the services weren't covered by the filters
- some minor fixes
Changelog:
4.1.0.0
- some minor fixes
Azbox HD Elite,Openrsi 3.0 Kernel v3.3.1,Samsung G3 Station 1TB , multifeed 4 lnb(28.2+23.5+19.2+13),Skylink,Samsung LE40B650
- schmegea
- Mazák
Re: DreamBoxEdit
- schmegea
- Mazák
Re: DreamBoxEdit
5.0.1.0
- added new hints in main list, now with bouquet references
- fixed application closing after canceling
- fixed error message after dropping service on current bouquet
- fixed main service list refresh after selection of another bouquet
p3k
Re: DreamBoxEdit
DreamBox Edit
5.0.2.0
- added configurable background color for transparent picons
- added transliteration support for cyrillic letters (only russian)
- added transliteration support for greek letters
- added option to enable/disable transliteration
- fixed some problems with very long servicenames
http://www.i-have-a-dreambox.com/wbb2/t ... did=135894
5.0.2.0
- gorick
- Mazák
Re: DreamBoxEdit
DreamBox Edit 5.1.0.2
- fixed error message in empty bouquet area when opening the context menu
- some language file updates
simonn2
Re: DreamBoxEdit
DreamBox Edit 5.2.0.0
Changes in 5.2.0.0
- added support for extended session-based security (WebInterface 1.7.4 and higher)
- added support for simple anti-hijack measures (WebInterface 1.7.3 and higher)
- added new error message when using picon cleanup function and an invalid filename was detected
- added paste from clipboard (E2 settings format), just copy&paste streaming services to your userbouquets
- fixed service type display issue
- fixed some localisation issues with cyrillic letters
Changes in 5.2.0.0
VU+ SoloSE V2 (vždy nejnovější VTi), AZBOX Elite HD (OpenPLi 6.1)
- schmegea
- Mazák
Re: DreamBoxEdit
Dreamboxedit 5.3.0.0
co je nového
- added transponder (satellites.xml) reload on service list reload
- fixed bouquetnames are now also written in UTF-8 on export
- fixed usage of profile picon path in service details
- added new skins: AlterMetro, GPlus
- some minor fixes
co je nového
- some minor fixes
- schmegea
- Mazák
Re: DreamBoxEdit
Dreamboxedit 5.3.1.1
co je nového
- added assign and remove of picons in main service list
- fixed color issues in compare dialog
- fixed zapping on Enigma1 boxes
- added new skin: Office 2013 Blue
- fixed window maximizing bug on startup
co je nového
- schmegea
- Mazák
Re: DreamBoxEdit
Dreamboxedit 5.3.1.2
- fixed some window scaling issues
- fixed some wine issues
- schmegea
- Mazák
Re: DreamBoxEdit
Dreamboxedit 5.3.1.3
- fixed non-working saturation and hue trackbar in color scheme options
vusolo2
- Dal poděkování: 40 poděkování
- Dostal poděkování: 63 poděkování
Re: DreamBoxEdit
dreamboxEDIT 6.1.1.0
6.1.1.0
- added support for non-TS streaming services with full reference
- added new AlterMetro 2016 skin
- added Latvian translation
- forced old style path selection dialog for Wine
- fixed multiple selections in bouquetlist
- fixed paste of IPTV services from clipboard with full reference
- OpenSSL security updates
Thx@dhwz dreamboxEDIT 6.1.1.1
6.1.1.1 - fixed update check
6.1.1.0
