HD Glass 16
Skiny pro přijímače VU+ DUO, SOLO, UNO, ULTIMO, ZERO.
vusolo2 Slovakia
Dal poděkování: 40 poděkování
Dostal poděkování: 63 poděkování
HD Glass 16
Příspěvek od vusolo2 »
HD Glass 16 ver. 11.00
- added detection of Ncam (after restore icons type will be set to default
type 1, so after update and autorestore you must download icons and previews
and then set/select your prefered icons type)
- piconCam updated in download
- weather: yahoo pressure autofix if yahoo generate wrong recalculate units
- updated and added et translation (thx zeros, Henkka) to eWea
- fix Find a city if is selected from main menu
- added new option: Detection Progressive/Interlaced in resolution info line
- updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
- help updated in download menu
- fix Channel number calculation
- added new Menu type: simply PIG
- added all config values to translations
- pridana detekcia Ncam (po obnove bude zmeneny typ ikon na 1, nasledne
je potrebne stiahnut znova sady ikon a ukazky a potom zvolit svoj oblubeny typ)
- piconCam aktualizovany v downloade
- pocasie: yahoo tlak autooprava ak je zly vypocet zo servera yahoo
- aktualizovany a pridany et preklad(thx zeros, Henkka) - eWea
- oprava "Najdi mesto" ak je predvolene pre Menu
- pridana nova volba: Detekcia Progressive/Interlaced v info riadku s rozlisenim
- aktualizovane pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
- help aktualizovana v ponuke stahovania
- oprava vypoctu cisla kanalu - infobar
- pridany novy Menu typ: simply PIG
- pridane vsetky cfg hodnoty do prekladov - aktualne len sk preklad obsahuje kompletny preklad
update is available online (setup and website)
Thx@shamann
vusolo2 Slovakia
Re: HD Glass 16
HD Glass 16 ver. 11.10
- updated enhanced weather translations
- fix multiple definition screens (deb version only)
- removed options: Autodetect HDD, Path to HDD, OLED dir, Picons/Icons path
- added option in section HDD: HDD and added new section "OLED"
- added options in section OTHER: Picons/Icons path, User defined path
- big optimalisation of the main code and changed definitions of some cfg values
so after update will be some cfg/function switched to the default value and you
can set your prefered options after autorestore:
Enable Enhanced Infobar
Second picon type
ECM line type
Volume type
HDD
Enable piconCam
Picons/Icons path
OLED dir
EPG selection type
Ignore infobar timeout
Enable control of network status
PIG type
- updated help sk, cz, en
- removed section "SCREENS", items moved to section "OTHER"
- fix Extra screen 8
- weather: fix MSN if wind direction is not available
- fix user info: system info, side bar
- aktualizovane preklady pre rozsirene pocasie
- oprava vicerych definicii obrazoviek (len deb verzia)
- zrusene volby: Autodetekcia HDD, Cesta k HDD, OLED adresar, Cesta k picons/ikons
- pridana volba v sekcii HDD: HDD a pridana nova selcia "OLED"
- pridane volby v sekcii OSTATNE: Cesta k picons/ikons, Uzivatelom def. cesta
- rozsiahla optimalizacia hlavneho kodu a zmenene def. niektorych cfg hodnot,
po update budu nastavene na predvolene, je mozne ich nastavit na oblubene
nastavenie az po auto obnove nastaveni:
Povolit rozsireny Infobar
Typ druheho picon
Typ zobrazenia pre ECM line
Typ zobrazenia hlasitosti
HDD
Povolit piconCam
Picon adresar
OLED adresar
Typ zobrazenia pre Jeden EPG
Ignoruj casovy limit infobaru
Povolit kontrolu stavu siete
Typ PIG
- aktualizovana napoveda sk, cz, en
- odstranena sekcia "SCREENS", polozky presunute do sekcie "OSTATNE"
- oprava infobaru 8
- pocasie: oprava MSN ak nie su info o smere vetra
- oprava user info: system info, bocny panel
Thx@shamann
vusolo2 Slovakia
Re: HD Glass 16
HD Glass 16 ver. 11.22
- changed User defined path to selection of dir by using Location box, if is
Picons/Icons path used as User defined path the one will be set to default value
and you can set your prefered options after autorestore
- updated help sk, cz, en, lt
- setup of the skin: added moving to last item/section if is active first item
press Up/Ch + and moving to first item/section if is active last item press
Down/Ch -
- fix TP info a ECM status
- added new option: Calculation of channel numbers - static/dynamic, section OTHERS
static - recommended for old HW
- added color "grey 5" at all color selection
- added new option: Date format - in sections: INFOBAR/EXTRA INFOBAR, OTHERS,
CHANNEL SELECTION, MENU
- splitted section INFOBAR to sections: INFOBAR,EXTRA INFOBAR,INFOBAR/EXTRA INFOBAR
- added new options: Date (color), Time (color), Seconds (color) in section
EXTRA INFOBAR
- added autodetection of possible OLED type by hw
- fix detection of decoding type - dynamic icons
- added autohiding of options unusable in image/hw
- zmenena Uzivatelom def. cesta na vyber adresara s pouzitim Location box, ak je
Cesta k picons/ikons nastavena na Uzivatelom def. cesta dojde k jej resetnutiu
na defaultnu, po auto obnove nastaveni je mozne ju nastavit na oblubenu
- aktualizovana napoveda sk, cz, en, lt
- nastavenie skinu: pridane prepnutie na poslednu polozku/sekciu ak je zvolena prva
stlacenim hore/Ch +, a presun na 1 polozku/sekciu ak je zvolena posledna
stlacenim dole/Ch -
- oprava TP info a ECM stav
- pridana nova volba: Vypocet cisla kanalov - staticky/dynamicky, sekcia OSTATNE
staticky - odporucane pre starsi HW
- pridana farba "seda 5" vo vyberoch vsetkych farieb
- pridana nova volba: Format datumu - v sekciach: INFOBAR/EXTRA INFOBAR, OSTATNE,
VYBER KANALOV, MENU
- rozdelena sekcia INFOBAR na sekcie: INFOBAR,EXTRA INFOBAR,INFOBAR/EXTRA INFOBAR
- pridana nova volba: Datum (color), Cas (color), Sekundy (color) v sekcii
EXTRA INFOBAR
- pridana autodetekcia mozneho vyberu typu OLED podla hw
- oprava detekcie typu dekodovania - dynamicke ikony
- pridane auto skrytie volieb ktore v image/hw nie je mozne aktivovat
Thx@shamann
vusolo2 Slovakia
Re: HD Glass 16
HD Glass 16 ver. 11.34
- updated enhanced weather translations: sk, cz, en, et, lt
- updated pl, sk, cz, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
- updated help translations: sk, cz, lt, ru
- INFOBAR: removed - Simple base infobar
- INFOBAR/EXTRA INFOBAR - removed - Date format
- INFOBAR: added - Date format
- INFOBAR: added - Standard Infobar type (including def. Simle base infobar)
- EXTRA INFOBAR: added - Date format, Channel name (color), Event now (color),
Event next (color)
- OTHERS: added - Ignore leading 0 in time
- INFOBAR: added - Standard Infobar type - Standard2
- fix channel number calculation - static
- MENU: added - menu type - with PIG2, with PIG3, with PIG4
- updated in download menu - Menu icons big
- fix date format parser
- added support and detection of DVB-S2X system
- TUNER: added - Hide tuner in standby or missing
- added Extra Infobar 54
- added support for DM900UHD
- OTHERS: added Single EPG type: with PIG(+number, ch.name)2
- OLED: added - oled type (DM900UHD, Vu+ 4k) - Classical, with ZZPicon
- changed Location box to Dir browser for path setting of picons/icons
- HDD: added type Auto (autodetection)
- aktualizovane preklady pre rozsirene pocasie: sk, cz, en, et, lt
- aktualizovane: pl, sk, cz, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl,
et, lt
- aktualizovane preklady pre help: sk, cz, lt, ru
- napoveda aktualizovana v ponuke stahovania
- INFOBAR: zrusene - Jednoduchy zakladny infobar
- INFOBAR/EXTRA INFOBAR - zrusene - Format datumu
- INFOBAR: pridane - Format datumu
- INFOBAR: pridane - Typ standardneho infobaru (obsahuje def. pre zakladny infobar)
- EXTRA INFOBAR: pridane - Format datumu, Nazov kanalu (farba), Akt. program
(farba), Nasledujuci program (farba)
- OSTATNE: pridane - Ignoruj 0 ak cas zacina 0
- INFOBAR: pridane - typ standardneho infobaru - Standard2
- oprava vypoctu cisla kanalu - staticky
- MENU: pridane - typ menu - s PIG2, s PIG3, s PIG4
- aktualizovane v downloade - Menu ikony velke
- oprava parsera pre format datumu
- pridana podpora a detekcia DVB-S2X systemu
- TUNER: pridane - Skryt tuner v pohotovosnom rezime alebo chybajuci tuner
- pridany Extra Infobar 54
- pridana podpora pre DM900UHD
- OSTATNE: pridany typ pre "Jeden EPG" - s PIG(+cislo, nazov kanalu)2
- OLED: pridane typ OLED (DM900UHD, Vu+ 4k) - Klasicky, s ZZPicon
- zmeneny Location box na Dir browser pre nastavenie cesty k picons/icons
- HDD: pridany typ Auto (autodetekcia)
Thx@shamann
vusolo2 Slovakia
Re: HD Glass 16
HD Glass 16 ver. 11.38
- fix getting of HDD tmperature
- edited: Standard Infobar2 and Extra Infobar 33, 54 and Extensions list
- CHANNEL SELECTION: changed - New style(colored list) changed to New style2
- added Extra Infobar 55, 56
- help, extrascreens graphics a previews updated in download
- OLED: added - oled type (DM900UHD, Vu+ 4k) - Classical2
- fix USER INFO - system info
- WEATHER: fix SSL certificate error - Yahoo provider
- fix management of path setting of picons/icons
et, lt
- oprava ziskania teploty HDD
- upravane: standardny infobar2, extra infobar 33, 54 a zoznam rozsireni
- VYBER KANALOV: zmenene - typ Novy styl(farebny list) zmeneny na Novy styl2
- pridany Extra Infobar 55, 56
- OLED: pridane - typ OLED (DM900UHD, Vu+ 4k) - Klasicky2
- oprava pre USER INFO - system info
- napoveda, extrascreen grafika, a ukazky aktualizovane v ponuke stahovania
- POCASIE: oprava chyby certifikatu SSL pre Yahoo v OE 2.5
- oprava riadenia pre nastavenie cesty k picons/icons
Thx@shamann
enigma2-skin-hdglass16_11.38_all.ipk.zip
vusolo2 Slovakia
Re: HD Glass 16
HD Glass 16 ver. 11.63
- updated lcstrings.list
- fix displaying title of Channel selection
- fix extra EPG renderer
- aktualizovany lcstrings.list
- oprava zobrazenia titulu vo vybere kanalov
- oprava extra EPG renderera
Thx@shamann
enigma2-skin-hdglass16_11.63_all.ipk.zip
vusolo2 Slovakia
Re: HD Glass 16
Thx@shamann
vusolo2 Slovakia
Re: HD Glass 16
HD Glass 16 ver. 11.65
- oprava renderera orezavania title
- opravy/korekcie roznych screenov
- pridana alternativna metoda pre overenie dostupnosti aktualizacie
ak sa online aktualizacia neponuka mozte spravit 1 z nasledujucich moznosti:
1. zmenit IP adresu v kapitole "SIET" v nastaveniach HDG (aktualne pouzita nefunguje) potom skusit online update znova
alebo
2. instalovat manualne ipk/deb 11.65 a dalsi update uz bude fungovat normalne
[/color]
Thx@shamann
enigma2-skin-hdglass16_11.65_all.ipk.zip
vusolo2 Slovakia
Re: HD Glass 16
HD Glass 16 ver. 11.67
- fix/corections more of screens
- fix support extended version of bitrate plugin
- changed update dialog
et, lt
- oprava podpory pre rozsirenu verziu bitrate pluginu
- zmeneny dialog pre aktualizaciu
Thx@shamann
enigma2-skin-hdglass16_11.67_all.ipk.zip
vusolo2 Slovakia
Re: HD Glass 16
HD Glass 16 ver. 11.70
- added alternative method to detect IPTV stream
- WEATHER: added support of SSL certificates
- OTHER: removed - user encoding.conf (deb version only)
- fix oscam ymod version detection
- added detection of modulation 16APSK, 32APSK (DVB-S/S2 only)
et, lt
- pridana alternativna metoda detekcie IPTV stream-u
- POCASIE: pridana podpora pre SSL certifikaty
- OSTATNE: odsranene - user encoding.conf (len deb verzia)
- oprava detekcie oscam ymod verzie
- pridana detekcia modulacie 16APSK, 32APSK (len pre DVB-S/S2)
Thx@shamann
enigma2-skin-hdglass16_11.70_all.ipk.zip
vusolo2 Slovakia
Re: HD Glass 16
HD Glass 16 ver. 11.71
- Setup of HDG: removed numbering of chapters
- fix all Extra Screens: displaying 16APSK, 32APSK modulation
- Nastavenia HDG: zrusene cislovanie kapitol
- oprava vsetkych Extra Screenov: zobrazenie 16APSK, 32APSK modulacie
Thx@shamann
enigma2-skin-hdglass16_11.71_all.ipk.zip
vusolo2 Slovakia
Re: HD Glass 16
HD Glass 16 ver. 11.72
- added alternative method to searching of picons
- added next alternative method to searching of picons (if missing search 1_0_1...,
1_0_16..., 1_0_19...)
et, lt
- pridana alternativna metoda vyhladania piconov
- pridana dalsia alternativna metoda vyhladania piconov (ak chyba hlada 1_0_1...,
Th@shamann
enigma2-skin-hdglass16_11.72_all.ipk.zip
vusolo2 Slovakia
Re: HD Glass 16
HD Glass 16 ver. 11.77
- fix devices label (USB,HDD)
- restore cfg: changed to Dir browser with option to choose any .conf file
to restore cfg
- SETTINGS OF HDG: changed layout, removed function of blue and yellow button,
splitted function of green and OK button, button OK aktivates function of some
items, press green button to save cfg only
- fix screen History
- changed skin of all setup screens
- DOWNLOAD MENU: new skin and the new method of download - you can select items
to downlad and selected items are downloaded all at once
- HDG SETTING: added current path displaying in directory browser
et, lt
- oprava nazvov pre zariadenia (USB,HDD)
- obnova cfg: zmenena na prehliadac adresarov z moznostou zvolenia lubovolneho
suboru .conf s cfg ktora je pozadovana na obnovenie
- NASTAVENIA HDG: upraveny vzhlad, zrusena funkcia pre modre a zlte tlacitko,
oddelena funkcia pre zelene a OK tlacitko, OK aktivuje funkcie pri niektorych
polozkach, zelene tlacidlo sluzi len na ulozenie aktualnej cfg
- oprava obrazovky Historia
- zmeneny vzhlad vsetkych obrazoviek setup-u
- PONUKA STAHOVANIA: novy vzhlad a nova metoda stahovania - mozete vybrat polozky
na stiahnutie a vybrane polozky su stiahnute naraz
- NASTAVENIA HDG: pridane zobrazenie aktualnej cesty v prehliadaci adresarov
Thx@shamann
enigma2-skin-hdglass16_11.77_all.ipk.zip
vusolo2 Slovakia
Re: HD Glass 16
HD Glass 16 ver. 11.79
- dir browser: added path autocutting in title
- DOWNLOAD MENU: changed results layout after files download
- fix line hight auto settings in Channel selection
- fix ECM PID displaying (deb version)
- WEATHER: removed option "Find a city" (in extensions, in menu), added option
"Find a city" activated immediately press OK button
- added Extra Infobar 57
- fix "Find a city" Yahoo type searching
- TP INFO: extended support of HEVC codec
et, lt
- prehliadac adresarov: pridane auto orezavanie cesty v titulke
- PONUKA STAHOVANIA: uprava vzhladu vysledku po stahovani suborov
- oprava auto nastavenia velkosti riadku pre vyber kanalov
- oprava ECM PID zobrazenia (deb verzia)
- POCASIE: zrusena volba "Najdi mesto" (v rozsireniach, v menu), pridana volba
"Najdi mesto" aktivuje sa stlacenim OK
- pridany Extra Infobar 57
- oprava "Najdi mesto" vyhladavanie pre Yahoo
- TP INFO: rozsirena podpora detekcie kodeku HEVC
Thx@shamann
enigma2-skin-hdglass16_11.79_all.ipk.zip
vusolo2 Slovakia
Re: HD Glass 16
HD Glass 16 ver. 11.83
- updated enhanced weather translations: sk, cz, et, lt
- little changes in design of Extra Infobar 57
- fix some definition of screens
- added Multistream (MS) detection in TP info - appears only if it is in
the chapter: EXTRA INFOBAR enabled option: Show Satellite position in Tp info
- DOWNLOAD MENU: updated satellites table
- added enhanced method of picon searching
- fix CAID:PID info
- WEATHER: YAHOO - added option Show yesterday
- fix audio track type AAC detection
et, lt
- aktualizovane preklady pre rozsirene pocasie: sk, cz, et, lt
- male zmeny vzhladu v Extra Infobar 57
- opravy definicii niektorych screenov
- pridana detekcia Multistream (MS) v TP info - zobrazi sa len ak je v kapitole
EXTRA INFOBAR povolena volba: zobraz poziciu satelity v TP info
- PONUKA STAHOVANIA: aktualizovana tabulka satelitov
- pridana rozsirena metoda vyhladania picon
- oprava CAID:PID info
- POCASIE: YAHOO - pridana moznost zobraz vcerajsok
- oprava detekcie AAC audio stopy
Thx@shamann
Download https://www.sendspace.com/file/sagkjn
Zpět na „Skiny VU+ DUO, SOLO, UNO, ULTIMO, ZERO“
