Drivers and bootloader
fw (drivers) z 20110214
-improve live streaming playback (and vtuner)
-VOB AC3 fix
-VOB lpcm fix
-rc long standby keypress detection fix (needs frontpanel ver: "a" update)
-hdmi CEC support (write/read commands to/from /dev/hdmi_cec, cec message format <address><length><data1>...<dataN>)
-avoid claming cdc devices
-improve video mode change detection speed
Nove driver-i je najlepsie instalovat spolu s novym img PLI od 15.2.2011 odtialto: NIGHTLY OPENPLI BUILDS
Po preflashovani noveho img PLI s novymi ovladacmi je mozne este upgradovat novy bootloader, kde je odstranena aj chyba pri flashovani vacsich img.
Usb disk naformatovat v PC na FAT32, podobne ako pred flashovanim noveho img. Nakopirujte rozbaleny novy bootloader po adresar "ET9000" na usb flashku a postupujte rovnako ako pri upgrade img. Prijimac sa po preflashovani sam restartne.
-VOB AC3 fix
-VOB lpcm fix
Re: Drivers and bootloader
Drivers Update 2011-03-14
Changelog:
-support sending CEC commands when the tv is in standby
-disable lnb power in standby
-fixed lnb loopthrough in standby
-support increased lnb voltage
-fixed pip freeze when switching pip/main screen
-fixed switching from 24p to 25p mode
-support linuxtv dvr device (/dev/misc/pvr is still available for backward compatibility)
-fixed mp3 endoffile detection
-hd iframe 'pip'
Rozbalit a prekopirovat-prepisat v /lib/modules/2.6.18-7.4/extra... , alebo pockat na update v Open PLI ...
Changelog:
-hd iframe 'pip'
Drivers 19032011
20110319
-tune failed fixes
Rozbalit a prekopirovat-prepisat v /lib/modules/2.6.18-7.4/extra... restart boxu
20110319
-tune failed fixes
Drivers Update 2011-03-22
-fix simultaneous recordings
Drivers 2011-04-09
changelog:
-smartcard interface improvements
-media playback improvements
-AC3+/DDP support (use AUDIO_SET_BYPASS_MODE 0x22)
-vtuner: DVB-S2 support
-increased default alsa volume (pcm playback)
Diskusia tu: viewtopic.php?f=287&t=7480
changelog:
Drivers 2011-04-23
-Xvid
-Improved media playback
-Radio playback fix
-pip fix
-Video enhancement settings
Diskusia: viewtopic.php?f=287&t=7480
-Xvid
-Radio playback fix
-pip fix
New Drivers 2011-05-16
Changelog
- Media playback improved
- Xvid Fix
- Rotor fine tune Fix
- Blindscan Support
Note:
These Drivers will not work with CT-Image v1.1!
Please wait until CT-Image v1.2 is released.
img Open PLi z 18.5.2011 uz obsahuje nove driveri
Changelog
- Xvid Fix
- Blindscan Support
Note:
Driveri z 16.5.2011 sa nedaju pouzit do starsich imgs, vydanych do tohoto datumu. K dnesnemu dnu aktualizovali svoje imgs teamy Sifteam, Open PLi, HDFreaks, Power of Dream HD+, VIX team, Egami team, ktore uz posledne ovladace obsahuju. Vsetky nove imgs najdete na tomto fore... http://www.forum.satdigitalne.cz/viewforum.php?f=288
Caka sa na aktualizaciu img od Official support teamu (v.1.2)
New Bootloader 19.05.11
- umoznuje instalovat images o velkosti az do 100MB, predosla ver. z februara 2011 umoznovala instalaciu imgs do velkosti 60MB
- rozbalte a nakopirujte et9000 na usb flash disc a postupujte rovnako ako pri flashovani noveho image.
- po restarte zostanu Vase nastavenia zachovane
Drivers Update 2011-06-27
Changelog:
-increase framebuffer acceleration memory size
-always downmix audio on analog outputs
-support /proc/stb/fp/was_timer_wakeup (needs frontpanel update)
-vcr scart detection fix
-vfd improvements
-vfd: support greek and cyrillic charsets
-vfd: support additional symbols (see /proc/stb/lcd/*)
-pcm playback improvements
-sci improvements
Nakopirovat-prepisat v: /lib/modules/2.6.18-7.4/extra/ potom restart boxu.
Nedaju sa pouzit v Clarke-Support Image v1.1, pockat na v1.2.
Changelog:
-vfd improvements
-sci improvements
Bootloader update 19-07-2011
With UBIFS support
(UBIFS - zaklad pre nove images, ktore sa objavia v buducnosti.)
With UBIFS support
Mozna zmena uvodneho loga BL. Pred nainstalovanim BL, si zamente subor splash.bin v adresari bootloadera et9000.
linux drivers 2.6.31 for ET 9000 / 11.08.2011
- vfd: cyrillic/greek charactermap improvements
- scart: fix slowblanking
- alsa: fix playback of high bitrate pcm data
- fix mute status of ac3 in passthrough mode
- add 'use_advanced_remote
- add hdmi-cec ioctl
copy and replace the 4 extracted Files here: /lib/modules/2.6.31-3.2/extra
reboot.
Nove ovladace pouzit len v images, ktore obsahuju kernel 2.6.31!!!
reboot.
New Drivers 2011-09-18
-hdmi cec: signal address change with POLLPRI
-scaler sharpness: fixed 'neutral' value (middle of the scale)
-added video source viewport/clipping settings (/proc/stb/vmpeg/[0-1]/clip_*)
reboot.
reboot.
New Drivers 26-09-2011
-sci improvements (ORF-ICE)
-fix pip with webbrowser combination
reboot.
Clarke-Tech Support Team
Changelog drivers:
reboot.
Changelog drivers:
- MKV trickplay fix
- No channel lock fix (When no signal is available on the channel then the box reacts slow)
- Increase speed channel switching
- STC sync for video/audio/firstenable (DTS Downmix solution, need seperate dts code which will be released soon)
- SCI improvements (Final fix for orf-ice and some other adjustments)
- VFD: TS icoon by TimeShift (by activate timeshift the TS icoon on the VFD display light up)
- Scaler-Sharpness (0 - neutral) in the middle (13)
Bootloader test:
- change directory path to et5x00, et6x00, et9x00 (This will change even the address for the feed!!)Nemáte oprávnění prohlížet přiložené soubory.
